Perform this procedure to view the TCP and UDP configuration information for IPv6.
  1. Enter Privileged EXEC mode:
    enable
  2. Display IPv6 TCP connection information:
    show ipv6 tcp connections [vrf WORD<1–16> | vrfids WORD<0–512>]
  3. Display IPv6 TCP listener information for the specified IPv6 address:
    show ipv6 tcp listener [vrf WORD<1–16> | vrfids WORD<0–512>]
  4. Display IPv6 TCP properties
    show ipv6 tcp properties [vrf WORD<1–16> | vrfids WORD<0–512>]
  5. Display IPv6 TCP statistics
    show ipv6 tcp statistics [vrf WORD<1–16> | vrfids WORD<0–512>]
  6. Display IPv6 UDP information:
    show ipv6 udp endpoints [vrf WORD<1–16> | vrfids WORD<0–512>]
Switch:1>show ipv6 tcp connections
                     TCP connection table info - GlobalRouter
LOCALPORT    LOCALADDR         REMOTEPORT   REMOTEADDR           STATE
21           0:0:0:0:0:0:0:0   0            0:0:0:0:0:0:0:0      listen
23           0:0:0:0:0:0:0:0   0            0:0:0:0:0:0:0:0      listen
Switch:1>show ipv6 tcp listener
                    TCP listener table info - GlobalRouter
LOCALPORT    LOCALADDR
21           0:0:0:0:0:0:0:0
23           0:0:0:0:0:0:0:0
80           0:0:0:0:0:0:0:0
443          0:0:0:0:0:0:0:0
513          0:0:0:0:0:0:0:0
Switch:1#show ipv6 tcp properties
                   TCP Global Properties - GlobalRouter
RtoAlgorithm        constant
RtoMin              5002 milliseconds
RtoMax              60128 milliseconds
MaxConn             127
Switch:1#show ipv6 tcp statistics
                   TCP Global Statistics - GlobalRouter
ActiveOpens:        0
PassiveOpens:       5
AttemptFails:       0
EstabResets:        0
CurrEstab:          0
InSegs:             0
OutSegs:            0
RetransSegs:        0
InErrs:             0
OutRsts:            0
HCInSegs:           0
HCOutSegs:          0
Switch:1>show ipv6 udp endpoints
                            UDP endpoint table info - GlobalRouter
LOCALPORT    LOCALADDR
REMOTEPORT   REMOTEADDR                                      INSTANCE
PROCESS
69           0:0:0:0:0:0:0:0
0            0:0:0:0:0:0:0:0                                 1220866096 0
161          0:0:0:0:0:0:0:0
0            0:0:0:0:0:0:0:0                                 1220867644 0
